Removing lines on first layer and at layer change.
Greetings!
I'm having an issue as can be seen below where I have lines that are being on my prints. It's especially bad when it comes of the first layer since that's the layer I use as the "top".
First Layer
Layer Change Line
I have a Prusa Mk3s+ and have been trying to remove those issues for a while. The first layer issue happens even on a brand new build plate no matter where it is on the plate.
Printer: Prusa Mk3s+
Slicer: Cura
Filament: Prusament Galaxy Black
Temp: 210/70
Print Speed: 60mm/s
Retraction:
Retraction Settings
Thank you for any advice that may be!
RE: Removing lines on first layer and at layer change.
Quite frankly, the first thing that struck me was the 3.2 mm retraction length. This may be appropriate for a Bowden drive printer but not for the Mk3S+, where stock retraction length in Prusaslicer is 0.8 mm. So no idea what else might be wrong in your profile.
My suggestion: print it with Prusaslicer, to check whether the issue is with the slicer settings or something else.
