Reduce / limit / scale part cooling fan speed
the_master_1
(@the_master_1)
Hello all.
I have an original Prusa MK3S+ and a Fysetc MK3S+ clone. Long time I was using both printers using same profiles in Prusa slicer, they were fully compatible on the g-code level. Recently I had to replace the part cooling fan on the clone. I ordered Fysetc 05B5015H fan, which was advertized to be a better alternative for the originally used XYJ05S5015H. Unfortunately the new fan is louder than the old one and I assume also more powerfull / faster. Using this fan the quality has unfortunately declined (which is resulting in a strange stringing, which wasn't there before and which is eliminated again, when the part cooling speed is reduced by 80%). To be able to use same g-code files for both printers simultaneously I'm looking for a possibility to use only the 80% range of the new fan. This should be transparent to the g-code so I assume that I can only modify the firmware or do some kind of hardware modification the the fan?
Have someome any idea where to start? I wasn't able to find concrete advices or tutorials which would match this use case. Basicaly I would be able to compile a new firmware, but I'm not a programmer. I would also be able to solder additional electronic components but I need to know which ones 🙂
Thanks in advance!
This topic was modified 3 years temu by the_master_1
Opublikowany : 18/05/2023 4:55 pm
Firmware mods would have to be reinstated at every upgrade...
The simplest hardware mod would be to partially block the input to the fan, put a strip of something across the face so that it grabs less air per revolution.
Opublikowany : 19/05/2023 11:24 am
the_master_1
(@the_master_1)
RE: Reduce / limit / scale part cooling fan speed
Thanks for the idea Diem! Of course, this would be the easiest way, just to place a piese of cardboard in front of the fan.
But I would prefer an electronic or SW based solution, even if I have to compile the SW again before each update. I don't expect much development after the successor has come.
Opublikowany : 21/05/2023 8:57 am
Robin_13
(@robin_13)
I changed my cooling shroud with one for Printables and mentioned running a PID tune on the hotend.  Give it a try.
Opublikowany : 04/06/2023 5:59 pm
