Recent filament sensor error ?
I didn't have any filament sensor problem until recently.
It occurs randomly. The print would pause as if filament had run out. Unloading and loading of filament was then required to resume the print.
Cleaned the filament sensor as instructed by the handbook, but no improvement.
This happened since I updated to the latest driver and firmware (3.2.1).
It may be related or just an coincidence, I am not sure.
Anyone encounter the same problem ?
Napsal : 07/06/2018 9:24 am
Re: Recent filament sensor error ?
Are you also using different filament per chance? The sensor does not work correctly with some filaments (per the manual). Namely glossy black, some translucents, etc.
Napsal : 08/06/2018 8:00 am
