Reason of "Power Panic Detect"
Yuichi
(@yuichi)
During printing, my printer (i3 MK3S) was stopped by indication of "Power Panic Detect" together with beep sound.
And printing was recovered after indication of "Power Panic Detect" with beep sound but same thing occred over and over again.
It was also happened during recovery (thus, heating of bed and hot-end).
And finally, "Blackout occurred" was indicated (After recovery of the print, this situation had not been changed).
This isn't a one-time event.
I has used current printer since Apr-2018 (update to MK3S on Apr-2019) but It didn't happen before, but recently it started to happen.
As far as I can remember, it's only occurred in the last three or four months.
Could anybody advise what would be root cause of  "Power Panic" and what should I do ?
My current printing environment are below:
  • Printer: iK MK3S
  • Firmware: 3.9 .0 (3421)
  • Print: PETG (Hot-end: 250degC, Heated Bed: 90degC)
Opublikowany : 22/08/2020 11:46 am
gbryni
(@gbryni)
RE: Reason of "Power Panic Detect"
I have the same problem. I have been printing the last few days, and today it started with "Power Panic Detect" with a load beep sound.
I could not resume my print because the fault looped. I turned off my Prusa i3 Mk3s and tried again later, and then I started to print the same item from the beginning only this time the fault came closer to the end of the print. But still the looping fault message.
Would like some assistance with this problem. I know nothing about electronics, but if there is someone who have a tutorial I can follow that would be great.
Opublikowany : 03/10/2020 6:21 pm
1 ludzie polubili
Kartik Veliyath
(@kartik-veliyath)
I am having the exact same issue. Mine is worse though for PETG while PLA is somewhat less frequent with power panic errors.
This post was modified 3 years temu by Kartik Veliyath
Opublikowany : 30/06/2023 7:20 pm
