Rattling during XYZ calibration
walrus
(@walrus)
I recently changed a couple of things on my printer. I've had it for a week and it's been doing fine. Due to some advice from a friend after he saw the layers on the print, I tried tightening the x axis belt. I also took the chance to do some other quick maintenance. I removed the power supply from the frame (since I'm using an enclosure) and I replaced it with a support in https://www.prusaprinters.org/cheap-simple-3d-printer-enclosure/ . The final thing I did was clean off some cat hair from the rods and put a little bit of 3-in-one general purpose oil to replace any I rubbed off (the enclosure should prevent any more airborne cat hair from getting into the printer).
When running through calibration now, I get a bit of noise including a rattling sound.
I've gone through what I could think of that has changed - checking bolts and checking the zipties I replaced. But I also can't pinpoint where the rattling is coming from. When any individual axis is moving, I don't hear any problems (either by hand or earlier in the calibration). Any ideas on what I could look into next?
Opublikowany : 27/07/2018 1:17 am
walrus
(@walrus)
Re: Rattling during XYZ calibration
I just tried doing a quick print. The noise might be easier to hear in this video:
Opublikowany : 27/07/2018 4:42 am
thrawn86
(@thrawn86)
fairly normal, I am guessing that it ignores stealth/speed/acceleration during this process.
I would tear down your Y axis first, lube bearings from the inside and make sure the bearing races are properly aligned.
https://manual.prusa3d.com/Guide/2.+Y-axis+assembly/507?lang=en#s8321
Opublikowany : 28/07/2018 10:20 am
walrus
(@walrus)
Thanks for the suggestion! In the process of taking apart my y axis, I found out that one of the bearings there went bad. If I put the bearing on the rod, I have to push it to move it anywhere. It doesn't slide on it's own. That's probably causing at least some of my problems.
Opublikowany : 28/07/2018 10:34 pm
did you accidentally over tighten the U bolt?
Opublikowany : 28/07/2018 11:12 pm
walrus
(@walrus)
I tried to be careful about that. But, it was my first time putting a 3d printer together. So, yeah, there is a chance that I did. I don't know why it would take a couple of weeks to start causing problems though.
Opublikowany : 29/07/2018 4:00 am
