Raspberry Pi LAN or Wireless?
RavenOne
(@ravenone)
Which connection is best LAN or wifi for the Raspberry Pi?  And are there any configuration differences between them that need to be addressed (no pun intended)?
Publié : 27/03/2023 5:15 pm
JimB
 JimB
(@jimb)
RE: Raspberry Pi LAN or Wireless?
Either will work well.  For WiFi you'll of course have to configure the SSID/Password, but once you do that, you should not see much of a difference.  The real difference is running a cable vs wifi signal strength where the Raspberry Pi will be located.
Publié : 27/03/2023 7:21 pm
1 personnes ont aimé
If it is physically possible, I would prefer a LAN connection because it is usually faster, more stable and more secure. Setting up LAN or WLAN network connections on the Pi is easy for both methods.
wbr,
Karl
Publié : 27/03/2023 8:01 pm
TMS
 TMS
(@tms)
I've used old Rapsberry Pi 1 B rev 2 in both wired and wireless modes with Prusalink with no issues since the data throughput to the USB connector ofthe MK3S+ is actually low
Hope it helps
Publié : 27/03/2023 11:09 pm
RavenOne
(@ravenone)
Thanks guys!
Publié : 27/03/2023 11:21 pm
