Random Errors: WARNING - Received an error from the printer's firmware: HOTEND THERMAL RUNAWAY
bill.k12
(@bill-k12)
Have been printing for a few months without a single issue. Suddenly, I started receiving this message on occasion:
"WARNING - Received an error from the printer's firmware: HOTEND THERMAL RUNAWAY"
Here's a sample of a print:
Send: N1815 G1 X90.988 Y123.394 E0.68499*107
| Recv: ok
| Send: N1816 G1 X90.958 Y122.846 E0.01867*98
| Recv: ok
| Send: N1817 G1 X105.230 Y108.574 E0.68645*94
| Recv: ok
| Send: N1818 G1 X105.230 Y107.995 E0.01967*93
| Recv: ok
| Send: N1819 G1 X90.937 Y122.288 E0.68743*106
| Recv: ok
| Send: N1820 G1 X90.937 Y121.709 E0.01967*104
| Recv: ok
| Send: N1821 G1 X105.230 Y107.417 E0.68743*87
| Recv: ok
| Send: N1822 G1 X105.230 Y106.839 E0.01967*82
| Recv: ok
| Send: N1823 G1 X90.937 Y121.131 E0.68743*97
| Recv: ok
| Send: N1824 G1 X90.937 Y120.552 E0.01967*97
| Recv: Error: HOTEND THERMAL RUNAWAY
The printer crashes and displays a bunch of garbled text on the LCD screen. It does not respond unless I reset.
Printer: MK3s w/ 3.8.1 firmware (happened with previous version too, just upgraded)
OctoPrint: v1.3.12
Slicer: PrusaSlicer 2.1.1
Temps look stable otherwise. This happens with all material using the default temperature/print profiles in Slicer. I've checked all the connections and everything appears to be in order...
Sorry if I'm not providing enough info, I'm still kinda' new to this.
Let me know what you think, thanks!
Napsal : 24/01/2020 5:51 pm
RE: Random Errors: WARNING - Received an error from the printer's firmware: HOTEND THERMAL RUNAWAY
Check the ambient temperature, should be more than 15 degree; nozzlefanspeed to high; thermistor or thermistor cable defective or loose contact when axes are moving in X or Y or X/Y?
Try to initiate PID tuning
Napsal : 24/01/2020 7:17 pm
bill.k12
(@bill-k12)
Temperature's not the issue; it's in a temperature controlled office.
The PID Tuning passes without issues.
The temperature remains stable (+-.3C) until it fails completely. I'm going to try from a SDCard next.
If it bombs from a SDCard, I'm suspecting a thermistor issue. No idea where to get a replacement; living in the states makes it harder/slow to import from Prusa.
This post was modified před 6 years by bill.k12
Napsal : 24/01/2020 10:06 pm
Jay
 Jay
(@jay-10)
@bill-k12
I got the same issue as you did. Changed the thermistor and redid the PID tuning but the temperature of the hotend cant seem to reach the target temp when printing.
Napsal : 25/01/2020 2:27 am
@bill-k12
@jayang19
maybe you will find the solution here:
https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-assembly-and-first-prints-troubleshooting/hotend-thermal-runaway/#post-97920
Also check thermistor resistance; should have 100k. E3D thermistor you can find here:
https://www.matterhackers.com/store/printer-accessories/e3d-thermistor-cartridge
Also try to reduce fan speed and use silicone socket.
Napsal : 25/01/2020 2:59 am
