Random blobs on print
jlittle576
(@jlittle576)
Hi I am having random blobs appear on my print. Happened 2 more times before this layer was through
I recently replaced my PTFE tube after it got jammed, was not happening before
I was missing the brass insert at the top of the PTFE tube and using a plastic E3D blue clip instead
Any ideas?
This topic was modified 7 years temu 2 times by jlittle576
Opublikowany : 12/09/2019 8:02 pm
jlittle576
(@jlittle576)
RE: Random blobs on print
I disassembled last night, had some PLA pooled above the heat block, and somehow all over the heat break threads. Must be something up with the connection block/break/sink connection. Also somehow managed to break my heater cartridge wires and strip my thermistor set screw, so I just grabbed a whole new assembly with molex connectors for heater/thermistor so maybe when this happens again it'll be a little lass painful
Opublikowany : 13/09/2019 2:23 pm
