Quick Thought??
Rufus
(@rufus)
Quick Thought??
Hi I was wondering if someone knew why my 3s+ doesn't recognize the flash drive card after I pull it out?? I never had any issue but now when I load gcode and plug the card back into the slot it wont see it. I have to either power down or push the reset and then I can go to print from SD Card?? I would think if the card wasn't formatted correctly it would never see it. Should I try a new card??
Veröffentlicht : 01/11/2024 11:44 pm
Walter Layher
(@walter-layher)
RE: Quick Thought??
Perhaps the card got corrupted, e.g. when you pulled it out of the slot in your computer before a write operation was finished?
Did you try to format the card via the menu on the printer? This should format it in the right way to make it readable for the printer and readable/writable on your PC.
This will of course destroy the previous content of the card. If there is anything important on it, you should try to restore/recover it before formatting it.
Veröffentlicht : 02/11/2024 12:18 am
