Putting fill in between top layers?
Kenour
(@kenour)
I've got a print with three levels, on the top and bottom level the 7 top solid layers are being sliced correctly, but the middle level is 4 layers solid, 2 layers infil, top layer solid. Obviously this isn't going to work, just wondering why it decided to do it or how I can make it... not to it 😛 No issue with simplify, I just want to use Slic3r exclusively.
Napsal : 10/09/2018 3:10 am
Kenour
(@kenour)
Re: Putting fill in between top layers?
No ones seen this before? Should I report it on github, or is there a prusa version specific forum to report it on?
Napsal : 13/09/2018 12:29 pm
Tiago
(@tiago)
If you set 7 top solid layers then it should slice 7 solid layers at all tops, the only reason to only do 4 would be a low thickness, but i think is not your case on that massive object. Maybe slic3r is too smart and want to spare you some filament 😆
You can also share your stl to reproduce your problem
Napsal : 13/09/2018 2:43 pm
Kenour
(@kenour)
I know right!? 😛 Here's the STL
https://drive.google.com/file/d/1VlTjzIPtq9v0QpFE4XunSZRV8JxdT1RX/view?usp=sharing
Napsal : 17/09/2018 12:12 am
Worked for me Kenny, 7 layers all levels
Joan
Napsal : 17/09/2018 12:41 am
Tiago
(@tiago)
Joan
+1
Napsal : 17/09/2018 5:43 am
