[Rozwiązany] PursaLink 0.8.1 & PI Zero 2 W
AutoDrone
(@autodrone)
I am having issues with PursaLink 0.8.1 which is currently flashed onto my PI Zero 2 W. This was working fine for a day until I formatted and re-flashed it again this time enabling SSH for future Firmware updates using Putty remotely. Now I get a "No LAN" message on my printer. To attempt to fix the issue I formatted the SD card on the PI Zero again.. and reflashed Pursalink 0.8.1 disabling SSH as per following Pursa instructions....however with no change it will not connect the wifi or issue a IP address when connected to the printer. RPi is turned on, board LED is green, pins on board look good, close to WIFI router......no clue why it would work one day then not. (Clearly should have left it alone!)
Tonight, I will install PI Zero OS on it and connect a keyboard and monitor to test the WIFI module incase by fluke its not working anymore on the board.
Any ideas would be great, can only ChatGPT so many solutions....
AutoDrone
Opublikowany : 12/09/2024 10:29 pm
