PTFE Tube
Quams
(@quams)
PTFE Tube
After a PLA filament got stuck in the extruder, I managed to slightly lift the PTFE tube up into the extruder gears where it got shreddered. I mainly account that to my own stupidity and a bit to the bad design of the MK3s with MMU2s filament sensor which doesn't give easy access to the extruder gear any more.
But I really should have had another look before leaving the printer printing on its own.
I still have a spare tube that came with the MMU2s upgrade (so doing that upgrade finally has an advantage) but I really would like to have a spare. Big question: Where can I buy tubes already fitted to the MK3s? Can't find any in the prusa shop...
Best Answer by cwbullet:
Posted by: @jalbiez
@charles-h13
So I have to use the same account that I bought the printer with to get there?
Yes.  If you do not have access, contact support.
There are also jigs to help you make your own:
https://www.prusaprinters.org/prints/3644-ptfe-tube-chamfer-and-cut-jig/related
Opublikowany : 09/10/2019 9:05 am
RE: PTFE Tube
You have to login to the eshop.
https://shop.prusa3d.com/en/spare-parts/929-hotend-ptfe-tube-mk25s-mk3s-mmu2s.html
Opublikowany : 09/10/2019 9:28 am
Quams
(@quams)
RE: PTFE Tube
@charles-h13
Opublikowany : 09/10/2019 9:33 am
RE: PTFE Tube
Posted by: @jalbiez
@charles-h13
Opublikowany : 09/10/2019 9:43 am
1 ludzie polubili
