PT100 sensor and amplifier
Hi there,
apparently the firmware supports the PT100 sensor, with or without amplifier board. I am planning to install a PT100 sensor to be bale to increase the temperature above the 285 or 300°C stock. I know I need a better heater cartridge and probably a copper heat block.
Now, do I need the amplifier board or can I just connect the PT100 sensor (thermistor) along with the appropriate chnage sin the firmware?
Thx,
Michael
Opublikowany : 16/05/2018 9:36 am
