PrusaSlicer Question
kalehrman
(@kalehrman)
I have installed the latest version of PrusaSlicer and I get this block in on the bed of my printer.  I cannot delete it, I can move it, and when I arrange my items, it places it directly in the middle of the print bed.  I am not sure what this is and I am struggling with this being in the way with all of my parts that I print.  What is this item, what needs to be done to remove.  I don't see any of these on the videos put out by Prusa.
Respondido : 28/05/2019 9:24 pm
gnat
 gnat
(@gnat)
RE: PrusaSlicer Question
I expect you have selected an MMU printer, select the correct printer and it should go away (unless you are trying to do an MMU print).
As far as always putting it in the center, it sounds like maybe you have the auto arrange option turned on it your preferences. If you turn that off it will let you put things where you want.
MMU tips and troubleshooting
Respondido : 28/05/2019 9:31 pm
kalehrman
(@kalehrman)
Thank you @gnat!!  I had my printer selected as MMU2S.  When I changed to MK3S or MMU2S Single, the box went away.  So what is the box?
Respondido : 29/05/2019 1:13 pm
