Prusaslicer 2.5.2 not exporting g code properly
Dentalight
(@dentalight)
I am trying to slice and print a file for Prusa X axis supports. I downloaded from printables. It seems to slice properly, but when I export g code and place the SD card in the printer, hit Print from SD, click on the file, it goes through sorting files again. Then the printing screen comes up that is pictured below. Both nozzle and bed heat are set to zero and time is zero.
I just did a new slicer install and rebooted the computer and printer. I have not sliced in some time, so I am probably doing something stupid.
Any help is appreciated.
Thanks,
Neal
Respondido : 10/04/2023 7:58 pm
Hello
(@hello)
RE: Prusaslicer 2.5.2 not exporting g code properly
Can I confirm you are clicking the wheel that spins not the lower button on the lcd
Respondido : 10/04/2023 8:14 pm
Dentalight
(@dentalight)
Yes, I am pushing down on the wheel that spins.
Respondido : 10/04/2023 8:40 pm
JimB
 JimB
(@jimb)
Move the sd card back to your computer and copy the failing gcode file off it and compare it to the original on your computer to make sure they are identical.
Respondido : 10/04/2023 9:01 pm
Hello
(@hello)
Posted by: @dentalight
Sorry to ask that but many people make the mistake
Go onto printables find a model and download gcode file and transfer to sd card
Respondido : 10/04/2023 9:10 pm
Dentalight
(@dentalight)
I'm afraid that that is beyond my capabilities.
I think it is possible that it is a bad file. I may try to import a different X axis support build. Maybe from thingiverse.
Does anyone know of a replacement adjustable (belt) X axis download that they like?
Hello
(@hello)
Go to edit: that's for mini
Download top file gcodeand transfer to sd
Respondido : 10/04/2023 9:13 pm
Hello
(@hello)
Do above with this https://www.printables.com/model/3051-mk3-camera-mount/files
Respondido : 10/04/2023 9:16 pm
Dentalight
(@dentalight)
I think that I did download a gcode file into the slicer, not realizing that it did not need to be sliced.
I transferred it directly onto the SD card and it looks like it is printing OK.
Thanks for your help!
Respondido : 10/04/2023 11:05 pm
