PrusaSlicer 2.2.0 Disable Auto Speed
MKB
 MKB
(@mkb)
Print Settings -> Speed -> Auto Speed (Advanced)
Max Print Speed
I'm trying to set this setting to 0 to disable it for test proposes in a non Prusa machine. I'm getting "Input value is out of range". PrusaSlicer 2.2.0 (Win10). Is there something I'm missing?
Thanks
Publié : 19/11/2020 2:42 am
RE: PrusaSlicer 2.2.0 Disable Auto Speed
Autospeed is only used when other speed settings are all set to 0. When used, it uses the volumetric speed setting direct above to determine maximum speeds. I didn't get particularly impressive results with it.
What printer are you configuring for?
Publié : 19/11/2020 4:57 am
MKB
 MKB
(@mkb)
@bobstro
I'm trying to test Voron Switchwire speeds. I setup perimeters/ext.perimeters/solid.infill/infill to 80/40/150/150 and I got these speeds only in the first 3 solid layers.. after that the speeds get equalized in some way. I can see the preview in View-Speed.
Thanks
Ce message a été modifié il y a 5 years par MKB
Publié : 19/11/2020 7:14 am
MKB
 MKB
(@mkb)
@bobstro
Auto cooling
To get rid of the auto-speed, Auto Cooling has to be disable.
Publié : 25/11/2020 4:53 am
1 personnes ont aimé
