PrusaSlicer 2.0 and AMF files
m2tts
(@m2tts)
I thought that amf files were supposed to bring all the bodies in them into the same shared origin, but when I import them all the separate bodies are forced down onto the plate. The older versions of slcr PE did not do this.
The only workaround I see is to go to one of the bodies in the tree and right click onto it's settings icon and re-add the original amf file to it under "Add part". Then you have to delete all the original bodies. I consider this a big interface problem.
Publié : 12/06/2019 2:23 pm
RE: PrusaSlicer 2.0 and AMF files
If you can capture some screenshots and detail, it would be helpful to post an issue to Prusa's PS github page to make it official.
Publié : 12/06/2019 3:17 pm
Vojtěch Bubník
(@vojtech-bubnik)
Membre Admin
Vojtěch Bubník
(@vojtech-bubnik)
Membre Admin
There is a regression bug in PrusaSlicer 2.0 compared to the Slic3r PE 1.41.3, where the AMF is always considered to be a project file even if it has not been exported as such. This bug will be fixed in the upcoming PrusaSlicer 2.1.
Publié : 23/07/2019 12:50 pm
