PrusaLink and stuck white screen when booting
Barca95
(@barca95)
Hi everyone,
I recently updated my Prusa mk3s+ to the firmware 3.14.1 and I flashed a Raspberry Pi Zero 2W with the firmware prusalink-0.8.1.img.xz
I printed a compatible frame from "Raspberry Pi Zero 2 W frame for Einsy Rambo" by Galoth
When I try to turn on the printer with the Raspberry I get stuck in the image attached (and the X button doesn't do anything). I used a tester and doesn't seem to have contacts betweens pins. Pins measure 13.5mm instead of 12.5mm but even not fitting completely the raspberry (so trying far positions) I get the same situation. Does anyone have any ideas on how to solve this?
Thank you very much for your attention,
Andrea
Posted : 16/02/2025 9:53 pm
