Prusai3 Mk3 z calibration failed
Joint Lab
(@joint-lab)
I have an issue when I set up the automatic z-calibration axis. It is fine when both of the steppers go all the way up, but when it goes down to do the 9 point test it does not go beyond the point 1.
It says:
Calibration failed!
Check the axes and run again.
The real problem is that if I print one of the files that starts with the nine point calibration, the test is working fine, but if I make the calibration through the display, it does not work. Apparently, when I did the z calibration, the sensor was working, but failed to continue the test.
Postato : 23/05/2019 11:06 pm
Joint Lab
(@joint-lab)
RE: Prusai3 Mk3 z calibration failed
I raised the bed because I am using another heated platform, so I am guessing that it has something to do with the firmware of the printer itself
Joint Lab
(@joint-lab)
We had worked with the PEI spring steel surface for a while, but we are looking forward to print on a glass bed for better results with Peek. Also we are currently working on ambient temperatures of 250°C, so we figure it out that the glass bed have better results at the first layer. We had modify the firmware to adjust geometry changes in the past, but for an unknown reason, we can`t find out why this error is happening.
Postato : 24/05/2019 11:34 pm
