Prusa xyz calibration failing, custom size
3DPrintDen
(@3dprintden)
Hello,
Might be a long shot to ask but cant hurt. Sorry if this is the wrong section.
I built a custom sized prusa with prusa hardware. So the board and all the important stuff is original. I flashed a custom firmware where I edited the max_pos travel limits after homing in the configuration_prusa.h file. Flashed it and when moving the axis through the lcd it seems to be about the right size. However when I do an XYZ Calibration, after testing the X axis ir says failed and to check the pulley. Any one got any ideas? Is there another value I need to modify in the firmware? Im not familiar with this stuff and looking through the files I didnt really see anything that would be relevant. Any help is welcome. Thanks folks.
Napsal : 09/11/2020 4:13 am
RE: Prusa xyz calibration failing, custom size
Posted by: @gergo-b
Hello,
Which values (variables) exactly did you change in which firmware version?
Maybe it is sufficient to perform a factory reset.
Napsal : 09/11/2020 9:52 am
If the bed size is different, where / what did you source that has the embedded calibration points in the heat bed?  If whatever you purchased doesn't have those cal points embedded, the Prusa X and Y calibration will fail, regardless.
Napsal : 09/11/2020 8:07 pm
3DPrintDen
(@3dprintden)
@karl-herbert
I changed the travel limits after homing in the configuration_prusa.h file since it's quite a bit bigger than the original
Napsal : 10/11/2020 1:50 pm
3DPrintDen
(@3dprintden)
@tim-m30
As far as I know the pinda probe work with magnetic field or something like that no? The 4 circles on the original bed don't have magnets in them, only around them a few cm away. So technically that can be replicated. Unless there's something else embedded into the bed at those locations, but not as far as I can tell. If you happen to know what exactly those points hold I'd love to know
Napsal : 10/11/2020 1:58 pm
3DPrintDen
(@3dprintden)
Bump?
Napsal : 11/11/2020 10:41 pm
