[Résolu] Prusa slicer removes holes
Bryan Perschbacher
(@bryan-perschbacher)
Membre
I have not had this problem until just recently and the only settings I have changed are selecting to output Verbose G-code. I have turned that off and it still occurs. It is file independent because  it occurs on .stl files I have previously successfully printed just a couple day ago. A re-install of Prusa slicer did not fix it. As shown in the pictures the part cannot properly slice vertical holes. turning the part sideways allows the part to be sliced properly, but that's not the direction I want to slice it. Please help.
Publié : 25/05/2023 1:18 pm
Files > Save Project as
Publié : 25/05/2023 3:40 pm
RE: Prusa slicer removes holes
I'm betting they have accidentally changed the slice mode to close holes.  Attaching the saved zipped up 3mf project file as Diem requested should clear things up and confirm one way or another.
Publié : 25/05/2023 4:50 pm
