Prusa slicer printing 2mm high
m2bandit
(@m2bandit)
Hello, when I slice with cura it ran fine.
When I slice with prusaslicer the test line is fine then when it moves to print the model it starts atleast 2mm high.
I have no Z offset in prusaslicer and haven't modified the start code.
sample of gcode attached.
Publié : 14/03/2023 10:50 pm
JimB
 JimB
(@jimb)
RE: Prusa slicer printing 2mm high
Nothing was attached to your post.  But instead of the gcode file, save the project file (File -> Save Project).  Zip that .3mf file (forum silently rejects most file types, but accepts .zip) and post that.  The .3mf file will have all the setting you used.
Publié : 15/03/2023 11:20 am
m2bandit
(@m2bandit)
That's weird maybe it's not allowed on here. I don't use 3mf I use STL's.
; generated by PrusaSlicer 2.5.0+win64 on 2023-03-14 at 21:40:52 UTC
; external perimeters extrusion width = 0.45mm
; perimeters extrusion width = 0.45mm
; infill extrusion width = 0.45mm
; solid infill extrusion width = 0.45mm
; top infill extrusion width = 0.40mm
; support material extrusion width = 0.35mm
; first layer extrusion width = 0.42mm
M73 P0 R163
M73 Q0 S165
M201 X1000 Y1000 Z200 E5000 ; sets maximum accelerations, mm/sec^2
M203 X200 Y200 Z12 E120 ; sets maximum feedrates, mm / sec
M204 P1250 R1250 T1250 ; sets acceleration (P, T) and retract acceleration (R), mm/sec^2
M205 X8.00 Y8.00 Z0.40 E4.50 ; sets the jerk limits, mm/sec
M205 S0 T0 ; sets the minimum extruding and travel feed rate, mm/sec
M107
;TYPE:Custom
M862.3 P "MK3S" ; printer model check
M862.1 P0.4 ; nozzle diameter check
M115 U3.10.1 ; tell printer latest fw version
M83 ; extruder relative mode
M104 S238 ; set extruder temp
M140 S100 ; set bed temp
M190 S100 ; wait for bed temp
M109 S238 ; wait for extruder temp
G80 ; mesh bed leveling
G1 Z0.2 F720
G1 Y-3 F1000 ; go outside print area
G92 E0
G1 X60 E9 F1000 ; intro line
G1 X100 E12.5 F1000 ; intro line
G92 E0
M221 S95
; Don't change E values below. Excessive value can damage the printer.
M907 E538 ; set extruder motor current
G21 ; set units to millimeters
M83 ; use relative distances for extrusion
M900 K0.04 ; Filament gcode LA 1.5
M900 K20 ; Filament gcode LA 1.0
M107
;LAYER_CHANGE
;Z:0.2
;HEIGHT:0.2
;BEFORE_LAYER_CHANGE
G92 E0.0
;0.2
G1 E-.8 F2100
G1 Z.2 F720
;AFTER_LAYER_CHANGE
;0.2
G1 X79.181 Y64.716 F10800
G1 E.8 F2100
M204 S800
;TYPE:Skirt/Brim
;WIDTH:0.42
G1 F1200
G1 X79.931 Y64.097 E.02977
G1 X82.063 Y63.366 E.06897
G1 X114.967 Y63.366 E1.00692
G1 X115.331 Y63.316 E.01124
G1 X134.692 Y63.32 E.59247
G1 X135.04 Y63.366 E.01075
G1 X167.89 Y63.366 E1.00526
G1 X169.204 Y63.681 E.04135
G1 X170.258 Y64.235 E.03644
G1 X171.223 Y65.151 E.04072
G1 X171.889 Y66.239 E.03902
G1 X172.285 Y67.757 E.04803
G1 X172.285 Y146.938 E2.42309
G1 X171.969 Y148.25 E.04127
M73 Q0 S164
Publié : 16/03/2023 4:49 pm
m2bandit
(@m2bandit)
I updated to prusaslicer 2.5.1 and deleted all of my presets, hopefully that resolves it.
Publié : 16/03/2023 6:21 pm
