[Résolu] Prusa Slicer missing layers imported from Rhino 3d
Albula
(@albula)
I exported a model from Rhino 3d and imported it into Prusa Slicer.
The strange thing is that when I slice it there are some layers missing.
Does somebody eventually have the same problem?
Cheers
Publié : 10/12/2022 8:59 am
RE: Prusa Slicer missing layers imported from Rhino 3d
See the triangle next to the parts name? Your STL is not properly formed. I'm no Rhino person, so don't know what it takes to produce a correct STL but you can try to run your model through something like https://www.formware.co/onlinestlrepair
Publié : 10/12/2022 11:18 am
Albula
(@albula)
You're the best. It works! Thank you
Publié : 10/12/2022 11:46 am
