Prusa Slic3r compile for RPi3 B+
Martin Stoufer
(@martin-stoufer)
Has anyone had any success with getting the source to compile on a Raspberry Pi 3 B+ I tried on a 'B' model and apparently the ARCH isn't correct. Otherwise, all the available packages available on Raspbian Buster look to be correct. Even the TBB debian package looks current enough.
I see the x86_64 build, but I wanted the challenge.
Napsal : 08/04/2019 10:05 pm
GeorgeE
(@georgee)
Re: Prusa Slic3r compile for RPi3 B+
I just used the standard octopi image on my B+ and connect it via USB.
Napsal : 09/04/2019 9:22 am
Martin Stoufer
(@martin-stoufer)
Thanks George, that was my fallback and after like 15 minutes, I was up and running.
Does the Slic3r that comes with Octopi fully leverage all the custom Prusa config, or do we need to load all those profiles in?
Still, I was looking for a challenge, and apparently a B+ now as the B has an earlier ARCH level that does not support inline assembly code in the Prusa slicer build.
Napsal : 10/04/2019 9:43 pm
Vojtěch Bubník
(@vojtech-bubnik)
Member Admin
There is no Raspberry PI (or ARM) build available as of now. If you love the challenge, then you are best to search through the open issues at
https://github.com/prusa3d/slic3r/issues
https://github.com/prusa3d/Slic3r/issues/1050
https://github.com/prusa3d/Slic3r/issues/564
and you may try to compile Slic3r yourself. The current master code is C++ only (there is some Perl bindings available for libslic3r, but that is not compiled by default and it is used by the unit / integration tests only.
Napsal : 12/04/2019 1:38 pm
