Prusa MKS3S+ Restarting on Load Filament/Preheat
zstetter
(@zstetter)
Hello, I am having a problem with my MKS3S+ as it self-restarts every time that I attempt to load/unload filament or adjust the temperature through either the 'preheat' setting or through the settings menu.
I was having some trouble loading filament into the extruder earlier, so I partially disassembled the unit (per the instructions on the website) to make sure that the tube was clear. The filament wasn't getting pushed through the nozzle, and seemed to be catching. After making sure that the path to the nozzle was clear, I preheated the nozzle and switched it out for a new one.
However, now when I try to do anything (it seems temperature related) the unit restarts. I ran the self-check calibrator and it seemed to run through all the steps without issue, and I've also re-flashed the firmware onto the machine. Any thoughts as to what could be causing this?
Thank you
Opublikowany : 04/11/2024 11:15 pm
