Prusa MK3S Z axis not moving down past center (see video)
[Risolto] Prusa MK3S Z axis not moving down past center (see video)
chewie
(@chewie-2)
Utenti
Hi all, I’m struggling to fix this issue and would appreciate any guidance. Since replacing the Pi Zero with a Pi Zero 2, I’ve been having problems calibrating the Z-axis. Even with the unit powered off and manually rotating both lead screws at the same time, the Z-axis will not move down past the midpoint.
https://storage.googleapis.com/prusa3d-content-prod-14e8-wordpress-forum-prod/2025/12/67e542fd-prusa-mk3s-z-axis-not-moving-down-past-center.mp4
Printer model & firmware: Prusa MK3S (latest firmware)
Filament type & brand: issue occurs before printing, but mainly pring PETG
Slicer & version: PrusaSlicer (current version)
Print settings: Defaults (no changes). I have also performed a factory reset
What I’ve tried: Powering the unit off and manually rotating both Z lead screws in unison; no visible obstructions or damage
Any suggestions would be appreciated.
Thank you.
Questa discussione è stata modificata 5 months fa da chewie
Postato : 17/12/2025 3:37 am
chewie
(@chewie-2)
Utenti
RE: Prusa MK3S Z axis not moving down past center (see video)
Well, I’ll be darned — I had previously tried pushing down the Z-axis, but I guess I didn’t apply enough pressure. I found this post where someone had the same issue: https://forum.prusa3d.com/forum/english-forum-original-prusa-i3-mk3-5s-general-discussions-annoucements-and-releases/mk3s-z-axis-problem/
I gave it a firm push downward, and sure enough, all calibrations passed!
Postato : 18/12/2025 3:36 am
