Prusa MK3 resets when heating
Sassy
(@sassy)
For some reason my prusa kit keeps restarting when I attempt to preheat it.
I got it to preheat once during set up, but i had a calibration issue. (Z axis wasn't straight) once I fixed the calibration issue (got a "congrats you're perpendicular!" Message) I went to preheat the board to do the first layer test and the printer immedately reset, showing the welcome splash screen.
I have been searching the Internet for ideas but I need some help.
I have tried:
-Removing and re-adding all wires (making sure the order was red/black/red/black/red/black with the PSU two on the left)
-Taking apart the heat bed and rebuilding it to ensure the wires were touching
-Moving the printer to an APC battery backup to ensure
consistent voltage
-Moving the printer to a few different power outlets on other breakers.
People have been talking about the MK2 having the voltage issue of it not being adjusted correctly, but I can't find the option to do this on the MK3. What other ideas does everyone have? None of the cables appear to be pinched or damaged either.
Napsal : 01/07/2018 8:39 pm
4U2C
 4U2C
(@4u2c)
Re: Prusa MK3 resets when heating
I had this same problem and the fix was to replace the OEM PSU with a Meanwell NES-350-24 PSU. This one has more wattage and a cooling fan.
Good luck with this situation.
Napsal : 02/07/2018 12:43 am
Sassy
(@sassy)
An update:
I did some more testing and going through settings.
When I preheat the bed it works fine and heats up.
When I preheat the hot end it resets.
I'm in America if that helps; but I haven't heard that I'd have to buy my own powersupply while I was still considering buying this.
Is supplying my own PSU really a thing?
Napsal : 02/07/2018 1:46 am
Gato
 Gato
(@gato)
I’d contact support regarding this. Provide a video to move things faster. I’m in Oregon and been using stock PSU with no issues. It does the classic clicking noise but things work fine. If problem is psu or board or whatever part is faulty then support will send you a replacement
Napsal : 02/07/2018 2:14 am
Olef
 Olef
(@olef)
Definitely contact support. You have a fault. Your printer should not reset while heating. You may need a replacement Einsy board for instance. You do not have to replace your PSU to have a working printer, that is simply a choice some users have made.
Make a short video of the issue and send it to support, be prepared to wait a few days as they are insanely busy but they will help you out.
Good luck!
Napsal : 02/07/2018 2:29 am
Sassy
(@sassy)
I appreciate the feedback from everyone. I'm going to reach out to support. I took a video of me trying to heat the nozzle.
I also accidently showed that if I put the nozzle below it's current room temperature it doesn't reset (I put it to 16 C and it didn't do anything) but the moment you attempt to heat it the device reboots. (I bumped it up to 40 C)
I think that rules out the thermister as well, leaving just the hot end the PSU.
If anyone has any other ideas let me know, but I'm going to persue support first.
Napsal : 02/07/2018 3:16 am
Chris
(@chris-16)
i would bet it is shorted. you may have the wires backwards on the einsy or something similar.
Napsal : 02/07/2018 5:53 am
Sassy
(@sassy)
I thought that when it happened the first time so I checked the connections and they seemed to be fine. I removed every cable from the board anyways and put them back on. Everything checks out fine. The wires are all undamaged and the connections match up to the assembly guide.
I submitted a support ticket and gave the link to this forum post as well, hoping that the additional information in here will help them to troubleshoot.
Napsal : 02/07/2018 4:32 pm
Sassy
(@sassy)
Update: Support told me that the thermistor heat cartridge is likely the cause. They said it likely shorted out and are sending me a replacement. Since it worked once, I'm guessing it shorted out after that.
I'll update again if this fixes the problem.
Napsal : 03/07/2018 9:27 pm
Sassy
(@sassy)
Final update:
Support sent me a new heater cartridge (and I ordered a few spare to have on hand) and it fixed the issue!
When I removed the old heater cartridge I noticed that the two metal wires that connect to the cartridge didn't have the wire wrap far enough and it was causing a short.
Napsal : 09/07/2018 6:00 pm
Gato
 Gato
(@gato)
Good that you solved it and found real root cause. :ugeek:
Napsal : 09/07/2018 6:45 pm
Kevlar
(@kevlar)
RE: Prusa MK3 resets when heating
@michael-b105
Could you tell me exactly what the heater cartridge is? My prusa is out of warranty, and I'm having the same issue. Something went wrong with unscrewing the nozzle, there was a spark, and now my printer resets whenever the nozzle tries to heat up during initialization or diags. I think I need to order a heater cartridge. Do you mean the rectangular medal block that the nozzle screws into?
Thanks
Napsal : 22/06/2021 7:54 pm
Millman90
(@millman90)
Thanks
This is exactly what happened with mine. What exactly did you need to fix it? Any advice is greatly appreciated
Napsal : 29/10/2022 6:12 pm
mk3 series have 24 volt 40watt heaters
Napsal : 29/10/2022 10:10 pm
raheel
(@raheel)
I had this issue before, it's cause by the 90 degree bed wiring, the 3d printed part it is too tall and the extruder temp sensor wires hit against it.
Napsal : 31/10/2022 1:32 pm
desmohead1
(@desmohead1)
Hi, I just encountered this issue after I disturbed things when removing the nozzle.  Printer would reset as soon as I commanded nozzle heat.  Turns out the heater wires were shorted out.  I took out heater and was able to carefully push them apart with a small pick, which eliminated the short and fixed my problem.  Hope this is helpful for others.
Napsal : 18/02/2023 7:39 pm
