PRUSA MK3 broken heartbreak?
Parker
(@parker)
IMG_0553
I was changing the nozzle on my PRUSA MK3S, I accidentally used a random nozzle (m6 thread) and I broke the heat cartridge, I was wondering if I dug into the inside threading of the heat block or have damaged the heat break.
Napsal : 11/07/2020 10:40 pm
CovertPluto3502
(@covertpluto3502-2)
RE: PRUSA MK3 broken heartbreak?
It's fine, just release the nozzle and screw the heatbreak and heatsink into the block. Then hot-tighten the nozzle and it should be just fine. Prusa has a tutorial on the assembly of the v6 as well as nozzle change.
Napsal : 13/07/2020 5:17 pm
Posted by: @whaleshark198
IMG_0553
Prusa MK3 nozzlechange:
https://help.prusa3d.com/en/guide/how-to-change-a-heatbreak-heaterblock-heatsink-mk3-mk2-5_14944
Napsal : 13/07/2020 6:04 pm
