PRUSA MK3 broken heartbreak?
I was changing the nozzle on my PRUSA MK3S, I accidentally used a random nozzle (m6 thread) and I broke the heat cartridge, I was wondering if I dug into the inside threading of the heat block or have damaged the heat break.
RE: PRUSA MK3 broken heartbreak?
It's fine, just release the nozzle and screw the heatbreak and heatsink into the block. Then hot-tighten the nozzle and it should be just fine. Prusa has a tutorial on the assembly of the v6 as well as nozzle change.
Prusa MK3 nozzlechange:
https://help.prusa3d.com/en/guide/how-to-change-a-heatbreak-heaterblock-heatsink-mk3-mk2-5_14944
