Prusa i3 MK3S Hotend / extruder replacment
HC093HE
(@hc093he-2)
Being an idiot I destroyed main parts of my hotend. As I'm a Pretty noob when it comes to 3D printing I've tried to figure out what's the best solution to replace the hotend but google didn't really help. Therefor: is the best solution to replace my broken hotend by the same version (couldn't find it in the Prusa store) or is there a better solution / upgrade solution for Hotend and / or Extruder I could consider? Any suggestion highly appreciated! Thank you very much in advance
Opublikowany : 24/02/2020 1:56 pm
vintagepc
(@vintagepc)
RE: Prusa i3 MK3S Hotend / extruder replacment
You need to be signed in to the store to see spare parts. If you are, and still cannot see them, talk to live chat, they may need to fix your account to allow access to the spares.
As you're new to this, just get the exact same parts. Don't complicate things with non-stock/OEM parts until you've got the basics under your belt and are familiar with the system and how it should operate. If it's stock, it's significantly fewer variables to troubleshoot when stuff goes wrong. If you've modded parts of it... for the most part you're on your own if the issue involves those areas.
Opublikowany : 24/02/2020 2:16 pm
