Prusa i3 MK3 Printing Issue
divya.k
(@divya-k)
I have been experiencing an odd print issue with my own designs and I’m not sure if it’s a PrusaControl problem or a print settings problem. I’ve attached a picture of last night’s print ( https://imgur.com/1t8CY2T ) that experienced this weird ‘failure’ which appears to consist of about 0.25” of bad layers then a return to normal print quality. For this parts’ STL file I turned the chord length down a bit and the angle up a bit since I have plenty of space on the SD card. Also I selected optimal layer height in PrusaControl with support material everywhere and brim option turned on. I ran this print at default heat/speed settings for PLA. Does anyone have any advice? Thanks!
UC browserSHAREitMX player
Opublikowany : 30/06/2018 4:56 am
Calire
(@calire)
Re: Prusa i3 MK3 Printing Issue
Hello.
Sorry but you are at the wrong space for a problem MK3. Here is for MK2/s.
You get more easy responses if you put in the good forum where more people can read you.
Opublikowany : 30/06/2018 8:43 am
Knickohr
(@knickohr)
Member Moderator
[mod mode on]
Moved topic to MK3-forum.
Thomas
[mod mode off]
Opublikowany : 02/07/2018 10:06 am
Asraff Amzani
(@asraff-amzani)
Try different material and also different pla filament. From the looks of it your extruder had some problems at that point
Opublikowany : 02/07/2018 10:49 am
