Prusa Control Hanging/Locking up
Dee
 Dee
(@dee-2)
Hi All,
I have had a problem with Prusa Control software.
I am trying to use it to insert colour changes into the GCODE, so my mk3 will prompt for a filament change (M600), however I have run into a few problems.
When importing a previously sliced model (GCODE sliced in Slic3r Prusa edition, or the samples from the SD card with the mk3) I can edit the layer and set the changes - but when exporting it, the save will stall at 98% (Windows) or 100%(Mac). The resulting file will be corrupted and unprintable.
I have managed to get it working by importing the STL and slicing it *within* Prusa control, however the slicing seems very limited.
Has anyone else noticed this or had similiar?
It seems for simple models, I can use Prusa control, but for more complicated models, I will need to do it the old fashioned way, by locating the layers in the GCODE and manually inserting the M600 lines by hand in Notepad++ - I don't suppose there is an easier way to do this with pre-sliced models that is a little more intuitive?
Any help appreciated!
Napsal : 18/05/2018 7:04 pm
