Prusa Connect - Continuous timelapse to SD card cannot be turned on
[Rozwiązany] Prusa Connect - Continuous timelapse to SD card cannot be turned on
CZaMOR
(@czamor)
Hi, why can't I turn on "Continuous timelapse to SD card"? It turns off immediately after turning it on. Original Buddy3D camera and Prusa MK3S+. The SD card is read by the printer and works. The camera also works in Prusa Connect without any problems.
Opublikowany : 25/11/2025 8:07 pm
CZaMOR
(@czamor)
RE: Prusa Connect - Continuous timelapse to SD card cannot be turned on
My mistake, I have a new camera, and I thought it would save to the SD card in the printer. After inserting the SD card into the camera, it is now working fine.
Opublikowany : 25/11/2025 8:27 pm
