Problems with PrusaSlicer 2.0 and 250mm width object
with the old software i was able to print a object that is 250mm width.
Now the Slicer told me, that there is a object outsite of the printing area.
Please help 🙂
Regards
Tobi
RE: Problems with PrusaSlicer 2.0 and 250mm width object
did you turn off that small skirt loop?
The arrange tool does only work for objects < 250mm. IMO that's a bug and should be ≤ 250mm.
The skirt must definitely be switched off. It is hard to see from your picture, but you might be off a ⅟₁₀ or a ⅟₁₀₀ from the print area. Maybe your angle is off.
Take a close look at the borders. There will be a darker spot where you are outside the area.
Yes thank you... the skirt was the problem.
In the old version i printed it with skirt.... and it works fine. On the sides the skirt hangs down but all runs well.
So to turn off the skirt solves the problem 🙂
