Problems Installing Klipper Firmware on Prusa MK3S+
Alk1s
(@alk1s)
Hey everyone,
I’ve been trying to install Klipper on my Prusa MK3S+ but ran into a couple of issues:
When flashing the Klipper firmware, the process got stuck at the end and didn’t finish properly.
I couldn’t find a good, reliable printer.cfg for the MK3S+ that worked out of the box.
My setup:
Prusa MK3S+ with stock E3D V6 hotend
Stock Bondtech-style extruder
Stock PINDA sensor
Raspberry Pi 4B (4GB RAM) running Fluidd
MCU connected via USB (serial: usb-Prusa_Research__prusa3d.com__Original_Prusa_i3_MK3...)
Also, do I need an AVR programmer to flash the firmware, or can it be done just through USB?
If anyone has advice or a solid config to share, I’d really appreciate it!
Opublikowany : 06/06/2025 4:35 pm
