        Problem with printing on i3 MK3
Hello, I am addressing you with a question about the printing problem of the i3 MK3 original Průša. The printer does not print directly after printing, but at a height of about 5 mm above it. Can you please tell me what the problem might be? The printer's firmware is up to date, and the slicer is updated to the latest version. Thank you for your response.
                            Posted : 05/09/2018 9:15 pm
                    Re: Problem with printing on i3 MK3
That sounds like your PINDA sensor is not mounted on the right height and that you maybe did not (or could not) do 1st layer calibration (setting the right Live Z value)
                            Posted : 06/09/2018 10:20 am
