Problem with printer firmware to any of the versions after 3.5.1
marcos.g3
(@marcos-g3)
I hope you can solve a problem I have. I recently purchased a Prusa I3 MK3 printer (I have been with it for about 1 month), the problem is that when I upgrade the printer firmware to any of the versions after 3.5.1, when doing the Selftest I get an error in the fan of the extruder.
However, if I upgrade to the obsolete version 3.5.1 everything is fine.
I am looking forward to your response.
Thanks for everything
Postato : 09/03/2019 8:35 pm
karl.w4
(@karl-w4)
Re: Problem with printer firmware to any of the versions after 3.5.1
same here!
Postato : 10/03/2019 1:29 am
RH_Dreambox
(@rh_dreambox)
There is no problem with your fan, read carefully what is on the screen. You should confirm how the fans behave.
It looks bewildering, but it is a check that the fans are properly connected.
I made the same mistake and started debugging, but when I read what was on the screen I understood that it was just a new test function.
So just confirm how the fans behave.
Postato : 10/03/2019 12:31 pm
marcos.g3
(@marcos-g3)
I Installed the last firmware (3.6.0) again and when I confirmed that the fan was spinning correctly, the selftest stopped and showed an error on the screen "Selftest error! Please check: Front/left fans Swapped".
I Checked the connexion of the fans and both are connected correctly. Please can you help me, what can I do? My printer is new (less than one month)
Thanks in advance
Postato : 10/03/2019 9:40 pm
marcos.g3
(@marcos-g3)
Sorry for the inconvenience, I did the self-test again and this time I read carefully what appears on the screen and you were right. The problem was me. Thanks again.
Postato : 10/03/2019 10:11 pm
