Problem with filament stepper motor after upgrade
K.E.S
(@k-e-s)
Hi, I have upgraded my prusa to 3.14.1 and drivers & apps 2.9.0. After that, I have got problem with my filament stepper motor and the scale (?). When I start a new print the problems comes out:
-> stepper motor is working with knocking in motor
-> filament is coming out of nozzle massively, like without any control, max speed
-> the print is smaller then slicer, like a half
I thought that my gcode may be a problem, but I tried to pull the filament out with standard operation from menu, and symptoms was the same, but the filament doesnt get out.
Napsal : 19/02/2025 6:10 am
juanapavalos
(@juanapavalos)
RE: Problem with filament stepper motor after upgrade
Filament water motor issues after firmware upgrade, including erratic motor behavior and uncontrolled filament extrusion. You should check the G-code and motor settings, which are essential to resolve these issues and restore proper printing functionality.
bartender the right mix
Napsal : 25/03/2025 3:29 am
