Problem with 9 Point Bed Leveling
Jenso Maroni
(@jenso-maroni)
Hello
I have a problem with the Z calibration. Almost every print start during the Z calibration of the 9 points results in a Z axis error.
The printer will then recalibrate and the 9 point measurements will start again. It happens up to 3 times that I have to recalibrate the z axis.
Obviously there are no mistakes in the assembly. Can it be due to the PINDA sensor?
Opublikowany : 31/03/2019 10:20 pm
Re: Problem with 9 Point Bed Leveling
Do check the obvious like making sure the nozzle is clean, and that there's nothing under the flex steel sheet. I started getting errors and was frustrated until I realized there was a bit of crud stuck on the magnetic heat bed.
Opublikowany : 31/03/2019 11:34 pm
