Problem flashing firmware from linux, i3mk3s
Running ubuntu 22.04 on a framework laptop, I recently upgraded prusa-slicer to 2.6.1, then tried to flash firmware to 3.13.1 on my I3MK3S. However, the config/upgrade firmware dialog showed the serial port device only, not the printer. I tried two different serial ports with the same result; powered on and off, restarted slicer, all with no change. Switching to an old microsoft surface go with slicer 2.3.3 allowed me to update it. Is anyone else with linux having this problem? I'm not sure whether or not I have ever updated the firmware from a linux system.
Veröffentlicht : 08/09/2023 5:40 am
