Problem display not work
Neodev
(@neodev)
Hi want start new print but the whell not turn for load filament I try to load and unload filament from menu but not turn, then menu not respond, then screen off and start a sound continuely
I go to off
Turn on an the display is off
The Mather board have led on and flicker as a normal, I wait look and then restart sound from display
Noè i must be change
Rambo or/and LCD?
Napsal : 12/11/2021 5:24 pm
Check all the electrical connections, pull and re-insert the plugs at both ends.
Napsal : 12/11/2021 11:42 pm
