Problem creating concentric-only print
Dear Fellow users,
I wish to print an all concentric pattern for a rectangular 3D shape. The purpose is to explore the mecanical and acoustic properties. That is why the pattern needs to be perfectly controled.
The problem is that the prusa slicer generates some layers (first and second to last -roughly) in a criss-cross pattern (purple on the video) and that is undesirable. I would like to have only concentric like the red pattern.
What am I doing wrong on the slicer?
Thank you in advance for your answer.
N
RE: Problem creating concentric-only print
this is probably down to
the highlighted settings
Joan
You can select concentric as the top and bottom fill patterns in the slicer.
`Twas exactly the problem.
Thank you Joan.
Happy printing!
Joan
