Prints no longer work, abort with "crash detected" message ( video inside )
bexxx
(@bexxx)
Hello,
after using my Prusa i3 for a year now i suddenly experience a weird behaviour, signalling "crash detected" when printing projects.
Everything i changed recently was adding a .6 nozzle and updating the firmware to the most recent version.
I did successful prints with this setup, without any issues after these changes, so i can really not explain what happened.
I use Octoprint and Prusaslicer in my printing-chain.
Here a quick video, you clearly see something is really wrong:
// edit video link here, embed function did not work for some reason
https://forum.prusa3d.com/wp-content/uploads/2021/06/Mein-Film.mp4
What i see is that the printer does not even extract any filament in this stage ( temperature are okay as the display shows me ),
and the initial filament load worked and extracted normally.
Any hint at which point to search for a problem?
Thank you very much !
This topic was modified před 5 years 2 times by bexxx
Napsal : 24/06/2021 5:58 pm
RE: Prints no longer work, abort with "crash detected" message ( video inside )
First check slicer Printer Settings > General > Bed shape
  -  Make sure the values are correct.
Then re-run  Calibrate XYZ from the lcd menu.
and come back if problems persist.
Napsal : 25/06/2021 8:07 am
