Printing with non prusament carbon fiber petg
Hi I was wondering I have the MK3S+ and want to print with carbon fiber infused petg specifically this https://a.co/d/bI3Uh3r
I want to know what nozzle to use and if this filament would work thanks.
Respondido : 05/03/2024 9:51 pm
RE: Printing with non prusament carbon fiber petg
Should work fine. You want to use a hardened steel, tungsten carbide, obxidian etc. nozzle, as the carbon fibers will not play nicely with brass nozzles. Some will suggest using a larger bore nozzle, such as 0.6 mm, which is certainly on the safe side, even though I have printed PETG-CF and PC-CF just fine with a 0.4 mm nozzle.
Respondido : 06/03/2024 2:39 am
