Printing replacement parts with eSun PLA Plus vs PETG
robert.c53
(@robert-c53)
Hi! New to 3D printing and began the build of the I3 MK3 last night. While using the tensioning bolt for the X-axis belt, I cracked the left X-axis mount. It's holding fine I think, but I'm hoping to print a replacement part once I finish the build.
Thing is, from what I've seen online glue won't help here. So I'm planning to print the replacement part. I only have some PLA Plus from eSun and the black filament that shipped with the Prusa right now. I was wondering if this filament will be able to serve the purpose or if I should wait to print it until I get some PETG? I haven't found any comparisons online that show if PLA Plus is close enough to PETG in strength, flexibility, and durability.
Thoughts?
Napsal : 22/09/2018 3:31 pm
Re: Printing replacement parts with eSun PLA Plus vs PETG
Pla should be fine for that part. No heat. Little stress... unless you crank on the belt adjuster...
Regards Joan
Napsal : 22/09/2018 5:50 pm
robert.c53
(@robert-c53)
Thanks Joan! 🙂
Napsal : 23/09/2018 3:30 pm
