Printing problems since update 3.7.2
Hey there.
We have some printing issuses since the last update. The surface of my print (especially the edges) are not clean. Please take a look at the picture. Is there anybody with the same problem? Does anybody have a solution?
I have printed the two parts together in the position you can see on the pictures.
I'd be glad to hearing from you!
Greetz, Bernd
RE: Printing problems since update 3.7.2
My guess is a problem in the gcode or even in the model, the stl. Are these something you can zip and post here?
Might not be the firmware.
X and Y positioning appear OK, but extrusion is highly irregular and has troubles with retraction restarts.
Is the Bondtech set screw loose or idler door tension wrong?
I've had some pretty dramatic effects when I sliced with the wrong nozzle size.
Judging by where the finger cutouts are, and that the inner part has none of the "issues", I'm thinking the part is supposed to be textured and all the messy looking bits are planned by the modeler.
