Printing problems
Peter Marek
(@peter-marek)
Printing problems
So i have MK3S printer and have a problem with it .
I downloaded new firmware and my motors are going super slow what should i do with it ?
Next thing is that i had problem with first layer and i downloaded 3.9.2 firmware but its even worse because now my extruder is not ever able to go to home position
Napsal : 30/12/2020 7:20 pm
RE: Printing problems
Posted by: @peter-marek
Is the printer built with original parts and did you flash the MK3S firmware?
https://cdn.prusa3d.com/downloads/firmware/prusa3d_fw_3_9_2_MK3S.zip
Napsal : 30/12/2020 8:27 pm
Peter Marek
(@peter-marek)
Its fully stock nothing changed since i got it from ESHOP
Napsal : 31/12/2020 8:00 am
mGoleta
(@mgoleta-2)
The assembly instructions for the MK3S kit I received a year ago said I didn't need to lubricate the axis rods.  That they bearing were pre-lubricated.  This turned out to be the problem in the initial setup.  After I lubricated the rods, I haven't had a problem since.  Did you successfully run the XZY calibration?  Where there minimal alignment errors for the axis?
Napsal : 31/12/2020 9:22 am
