Printing problems
So i have MK3S printer and have a problem with it .
I downloaded new firmware and my motors are going super slow what should i do with it ?
Next thing is that i had problem with first layer and i downloaded 3.9.2 firmware but its even worse because now my extruder is not ever able to go to home position
RE: Printing problems
Is the printer built with original parts and did you flash the MK3S firmware?
https://cdn.prusa3d.com/downloads/firmware/prusa3d_fw_3_9_2_MK3S.zip
Its fully stock nothing changed since i got it from ESHOP
The assembly instructions for the MK3S kit I received a year ago said I didn't need to lubricate the axis rods. That they bearing were pre-lubricated. This turned out to be the problem in the initial setup. After I lubricated the rods, I haven't had a problem since. Did you successfully run the XZY calibration? Where there minimal alignment errors for the axis?
