Printer won't turn on
I have a MK3S that I upgraded from MK2.5. It was running great had no problems, but It shutdown in the middle of a print. Now it won't turn on at all. I pulled the fuses and they all look like they are fine.
Any idea on what the issue might be?
Many thanks!!
Brian
Posted : 12/11/2019 7:03 pm
RE: Printer won't turn on
Did you check the power supply main fuse (in the power socket_?
A place to check for problems is the bed heater. Disconnect it at the Einsy and see if the printer powers up. If it does, then start ohming out the bed connections looking for a hard short.
This post was modified 6 years ago by --
Posted : 12/11/2019 11:01 pm
