Printer turned off while printing
maria del carmen.r
(@maria-del-carmen-r)
Hello all,
Our printer turned off on its own while printing twice, the first time we turned it back on, there was no error reported on the print. We tried printing again and it turned off again, but we couldn't turn it back up. We discover that the main fuse in the power source was dead so we replace it. The printer is still not responding, all other fuses are alright.
Does anyone have an idea of what is going on?
Napsal : 18/09/2020 5:40 am
Swiss_Cheese
(@swiss_cheese)
RE: Printer turned off while printing
My next step after checking fuses would be to check that all the connections are tight at the power supply and at the Einsy board.  the printer can move with enough force to cause a loose wire to dislodge and that could cause a short that could blow a fuse.
Of course be sure to unplug the machine before you check the connections.
The Filament Whisperer
Napsal : 20/09/2020 1:53 am
Posted by: @maria-del-carmen-r
Hello all,
I would also check the voltage of the power supply. This should bring constant about 24 volts.
Napsal : 20/09/2020 3:11 am
